XL Battery Question
  • 2 Replies
  • 2324 Views
A_Person
I have Arlo Pro 3 cameras and are looking to get extended life batteries. I am confused by the item description on the Arlo site. In the header, it says, "For Pro 3", but in the product description, it says, "Works with Ultra 2 XL, Pro 4 XL, Go 2 & Floodlight Cameras only.".
Will it work with a regular Pro 3 camera (non floodlight)?
XL Rechargeable Battery
For Ultra, Pro 4, Pro 3, Go 2 & Floodlight Cameras
Item No. VMA5420-10000S
$59.99
Up to 2.5 x the battery life. In those unexpected moments when your battery is depleted keep your Arlo cameras powered even longer. Perfect for high traffic locations, vacation homes or areas that are difficult to reach. The rechargeable battery lets you swap out the existing rechargeable battery in your Arlo camera for a fully charged one.
For Go 1 battery click here.
Ensure optimal performance and safety by only using Arlo approved batteries. See Details.
You also need to get the larger housing:
Note the bigger housing won't work with the magnetic mounts, you need screw mounts.  The threads are standard, so you don't necessarily have to go with Arlo branded ones.
A_Person
Great. Thanks a lot.
  • 2 Replies
  • 2324 Views
