Hi! Question regarding wind noise. I'm getting a lot of it! All 3 cameras are placed near an overhang so maybe wind is circulating through that area more and the camera is picking it up. Does the Pro 3 have any type of wind or noise cancellation? Theres a lot of false alerts due to this noise. I've also experienced a heavy delay in the camera picking up motion during my tests. Is this normal? Does it help to create zones? Would this make the cameras ability to pick up motion more accurate? Thanks for any help!
You can reduce the audio sensitivity in your modes and rules to see if that helps. You may need to reposition the cameras or even disable audio detection if the issue continues.
Motion sensitivity is also set in your modes and rules but first make sure that the cameras are properly positioned so motion is across the FOV and not at the cameras. There are FAQs here in the support area for camera positioning, changing sensitivity, creating new modes and rules and many other topics.
