  • 2 Replies
  • 1011 Views
Turkishexpress
I live in Chicago but plan on buying some Arlo Pro 3 cameras for our home in Turkey.  I can set up the cameras and do the subscription in the US.  But my question is, once I take the cameras to Turkey and connect them to the Wifi there, will they work?  Thanks in advance!
As long as the system is simply unplugged in the US and turned back on in Turkey it should work fine, as if you were still in the US. For subscription purposes, be sure to use a US credit card.
Turkishexpress
Ah perfect, thank you!!
  • 2 Replies
  • 1012 Views
