Wifi (x4) cameras stopped working
  • 5 Replies
  • 961 Views
hammo11
A couple of months ago, my 3 wifi pro3 cameras and floodlight all stopped working at the same time. I also have a wired doorbell camera and chime which have worked fine ever since and so the smart hub is connected and working fine.
I have tried resetting the router, smart hub and removing the batteries on the WiFi cameras but none of it worked so I then removed the cameras and tried to re-install but now it says they can't be found - I've tried auto and manually synching them.
We've had no issues with any other wifi devices in the house.
Can anyone give me some help please?
RobE22
Problem solved at my end: got the battery out and in again. Then it could be found again as a new camera. All 3 cameras are now functional again.
5 REPLIES 5
Did you try the hardware reset?
Open the camera housing and press the button inside until the camera LED flashes amber (~ 15 seconds).
Also, if you are using the app to install, try using my.arlo.com on a PC instead.  That sometimes works when the app fails.
hammo11
Hi Stephen
Yes, that's the sync button. I tried just pressing it and then holding it down until it flashed amber but still won't connect.
I'll try installing on a PC though, I haven't done that yet.
RobE22
Really exactly the same problem here. I did not notice a solution yet. Have you resolved the problem?
ShayneS
@RobE22
May I ask which troubleshooting steps you have tried so far? I don't want to suggest anything you have previously performed.
RobE22
  • 5 Replies
  • 962 Views
