Why is the UI different each time I open the library in the mobile app?
Why is the UI different each time I open the library in the mobile app? Aside from the annoying reminder that "cloud storage is faster", the look and feel changes each time. Sometimes I have to select a drop down menu at the top of the app to select local storage / cloud, other times there isn't a drop down. If there has to be a drop down, can it at least default to the current storage method? Finally, it is never apparent if it is still loading. I literally wait minutes while hoping it is loading, staring at that reminder that cloud storage is faster. Sometimes if I pull down it triggers the loading icon, other times pulling down does nothing. I like my Arlos and the app design isn't half bad, but man it's a pain since the experience is never the same and is grotesquely slow.
lilslugger,
Which version of the mobile app are you using (iOS or Android)? Are you able to provide some screenshots highlighting the specific differences you're noticing each time you open the app?
