Cloud storage does require a subscription, as do some other features.
You can see what you get w/o one here: https://kb.arlo.com/000062312/What-options-will-I-have-when-the-Arlo-trial-ends
You can set up direct access to local storage - though not as useful as cloud storage, there are folks here who use it instead of cloud storage (to avoid paying the subscription cost). https://kb.arlo.com/000062337/What-is-Direct-Storage-Access-and-how-do-I-use-it
Limitations include
- recordings only available from the app (not a PC browser)
- recordings only available from the primary account (not friend accounts)
- no ability to save manual recordings or snapshots
- no thumbnails
- remote access can be hard to set up (requires either port forwarding or a vpn)
Limitations include
- no thumbnails
