I am looking to buy a camera to cover my parking stall at my condo. There is no wifi or very weak wifi signal at the location I want to place the camera as my network doesn't reach that far. My window is 2 storeys above the entrance to the ground level parkade, and my stall is about 30 ft into the parkade. Would a camera be able to connect to a hub located on my window sill? If so, which model would you recomment I consider purchasing?
This could be difficult. You can try putting your router on the window sill, and see if the wifi from it will reach the parking stall.
Or if you get good cellular service at the parking stall, you could get a Go 2.
