VMB4500r2 - Local recording not show
  • 1 Reply
  • 1800 Views
tonyhua
hi all,
I am using Base station 4500r2
i have 4 devices: Three pro 3 and one Doorbell
my subscription is only for Doorbell, others I dont need
I just wanna all my pro CAMs work as normal, no need extra functions and setup them using Local storage
For some reason, i dont know, I only browse all clips from Doorbell, NOT from pro CAM
I checked my USB on PC, i found all clips were saved in there
but Library not show them, it shows only clips on Cloud
please help!
i can feel this is serious bug
thanks
thanks
Photo Mar 12, 7 31 36 PM.pngPhoto Mar 12, 7 31 45 PM.pngPhoto Mar 12, 7 31 54 PM.png
The VMB4500 requires that you safely eject the USB drive so you can view the videos on a computer. To use the app for viewing local recordings you need either the VMB4540 or 5000 SmatHubs - the older models don't support direct viewing.
  • 1 Reply
  • 1801 Views
