Us
  • 800 Views
joebeaster
I had a house fire and my base burned up. I bought another base and I'm having trouble connecting. I spoke with a tech person who knew nothing about the cameras and would not escalate the case so I'm stuck with cameras that I cannot connect to the base.
I know there's a way. I've tried resetting the cameras and I've connected the base but I still can't connect the cameras.
Now when I text for support, I'm told I have to pay, which is bs.
How can I connect the cameras to a new base and what steps need to be taken. I cannot find any reference on the arlo site.
Did you remove the cameras from your account before trying to re-install them?
If you are googling for a phone number, then you are likely reaching a scam support site.
Arlo support does require an Arlo subscription, but they do not sell you that subscription or otherwise charge you.
joebeaster
The base is recognized, the cameras are not.  I have reset the entire system and removed everything to start over from scratch.  I lost the base that came with the cameras in a house fire.  The cameras were mounted on the outside of the house and undamaged, the base, however, did not fare so well, and I had to buy another base, so I bought the VMB5000, which is fully compatible with the Arlo Pro 3 cameras VMC4040P.  I cannot see the cameras, and the app is not finding the cameras.
As far as support, it is outside of one year, so there is no support whatsoever.  The message I get claims that I can pay for support, but I cannot because there is no one to contact. When you get back to the chatbot, you are put into an endless loop leading nowhere and no service.  I am not even sure if the batteries are holding a charge as they do blink blue when disconnected from the charging port, but no lights when searching for a base to communicate with or find.
Did you try using a PC (my.arlo.com)?  That sometimes will work when the app fails.
Also, did you try a hardware reset on one of the cameras?  Open the housing and hold down the sync button inside until it flashes amber (! 15 sec).
  • 800 Views
