Timer
  • 2 Replies
  • 1268 Views
nealhayden
I see it was asked if we could use a timer outside of the set schedules.  For example, if my gardener comes outside their normal schedule.  I would disarm Arlo for 60 minutes and after the timer finishes, Arlo would re-arm automatically.  On the post asking for this, it says  "Solved! Go to Solution".  Is there a solution, I could not find it?
You can pause notifications for 60 minutes (or some other time intervals), but not recordings.
nealhayden
Oh....  I was trying to do this via the Windows Dashboard.  I see this is only available on the mobile app - thanks!!!
  • 2 Replies
  • 1269 Views
