  • 14 Replies
  • 7456 Views
  • 6 In Conversation
phanthanhtrung8
Hello,
I set up Arlo Pro 3 by using my laptop.
I also set up 2 step authentication on my laptop with SMS and email.
Then I log in on the Arlo app on my iPhone.
It raised an error that:
1. "Oops, An error has occurred. Try again"
I also try to choose another authentication.
However, there is no choice of Trusted This Device.
2. I tried to log in by using code sent by SMS and email.
It is also the same.
Please help me with this.
14 REPLIES 14
phanthanhtrung8
I attach screenshots here.
JessicaP
Hi phanthanhtrung8,
Try reinstalling the Arlo app and rebooting your iPhone to see if that helps. Are you also able to log in through the web client on your computer?
phanthanhtrung8
Hello,
I deleted the app and restarted my iPhone.
Even I tried my iPad and it still does not work.
Please check this issue.
Best,
Trung
phanthanhtrung8
I tried few devices.
I believed that this issue happens because of account setting or logic development of the Arlo authentication function.
Could you check it?
hungnpham
I have the same error.
phanthanhtrung8
Hi JessicaP, For more information, I and hungnpham used the Arlo Mobile App in Vietnam. I wonder if using app in Vietnam will cause any issue. Could you check this with app development team? Thank you for your help in advance.
hungnpham
i fixed it. please contact Fb volkapham
phanthanhtrung8
Hello JessicaP,
Do you have any solution?
I reset my ipad and iphone.
Even I chose factory setting.
I believe that this happens because of app and my account.
It is not the reason about my mobile phone or ipad
JessicaP
I'd suggest for you to contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
MarcinM
How did you guys fix it? I have the same problem in Vietnam.
It should be in Account->Profile->Login Settings->Two-Step Verification
Click on "add another method" and you should see an option to "trust this device".
MarcinM
I don't think your answer is relevant to the problem (see previous posts).
eminguyen
Having the same issue here, and in VN as well. Is this due to location issue. It is so annoyed. Please advise or fix. It always shows error message if I enter code for verification but works ok in pc
MarcinM
Temporary fix is to install a VPN on your phone
  • 14 Replies
  • 7457 Views
  • 6 In Conversation
