Snow Setting off Motion Detection
I'm having a big issue where a light snow flurry is setting off the motion detection recording literally constantly for the last several hours. I have HUNDREDS of recordings, as shown in my screenshot. Sensitivity is set to 10.
I tried searching and several other people seems to have this issue but none had any solutions posted. Hoping to get some more insight here because this is causing a lot of headaches. I can turn the camera off but that doesn't solve the actual issue.
Thanks!
Sensitivity set to 10 as in 10% or 10 (max)? I occasionally get recordings of rain or snow but unless the wind is really blowing it's not that many.
Glad I'm not the only one. Very odd behavior. You'd think the software would be smart enough to ignore things like snow or small bugs. *shrug*
NO resolution for me, still suffering through wasted footage of snow falling for minutes at a time. Then to make he situation even more frustrating, it doesn't pick up cars in the driveway about 30% of the time. Completely perplexing!
This morning I’m in the process of deleting the 136 recordings of snow falling from 3 cameras. Does anyone from Arlo read these posts?
No one has responded to my post early on about the motion sensitivity setting in modes and rules.
I have similar issues with light misty rain and spiderwebs. This typically only occurs after dark. During the day, false alarms tend to be shadows from trees. I just move past them.
