Smart notification option missing
Previously I had my cameras set up to only notify me when there's a person detected. A couple of days ago I started get flooded with "movement detected" notifications, and I can't find the option to disable it again. What's going on? Did the latest app update break something?
I still have it on IOS and web page. Is it possible your 3 month trial to Smart expired? Also check that all cameras are active under the smart subscription. I have had some knocked off before.
