Hej.
I installed my arlo pro 3 yesterday and I have two issues with it. One when pressing siren in the app, Nothing happens.
And second, yesterday I had 53 % battery. And today it dropped like a stone to below 10% the thing is that it is not even that cold. +10c what is the issue?
/dani
Dani82,
When you attempt to activate the siren, are you following the instructions listed here: How do I turn the siren on my Arlo Ultra or Arlo Pro 3 camera on or off?
Battery use depends on what the cameras are doing. Lots of triggers will eat the juice.
During set up you are likely to be doing things that cause a lot of traffic.
New batteries also take time to bed in. It may take a few charging cycles for them to reach capacity.
Just another user
Another common cause of rapid drain is camera resyncing. When the camera loses touch with the base, it will search for it - which will drain battery pretty quickly if it happens often.
Dani82,
Hej. i charged it up to full two days ago again. and now it is down to 1% again and it have not trigged more than 2-3 times. i have two other camera in similar setup and they have lost close to nothing. Im suspecting a faulty battery.
It are sitting in same area that 2 other cameras some even further away. and the reception bar indicated is 2 out of 3
Sounds like a good theory.
Try swapping the batteries between cameras and see if that changes which one drains.
That will show if it is the battery or the camera.
Don't forget that bit can take a few charging cycles for batteries to settle down. But what you see does seem abnormal.
Just another user
