Second arlo base station being used to extend range
The camera subscriptions are per-account, so it shouldn't matter that you have two bases.
You could try contacting support to resolve it: https://www.arlo.com/en-us/support/contact.aspx
Auntie64,
When you say the Arlo Pro 3 seems to want a separate subscription, what do you mean? What are you seeing?
Arlo Pro 3 comes with a 3 month trial subscription that you will see in addition to your existing subscription from the Ultra kit, but this shouldn't result in any negative impact.
Auntie64,
Check your Arlo Smart subscription settings to make sure all of the desired cameras are participating. This can be done by navigating to Settings > Subscription > Manage Cameras
I have added a sixth Arlo Pro 2 camera to my home. There is no way to place the base station to give a strong signal to all cameras.
From what I read, the best solution is to add a second base station. But I cannot find HOW to add the second base station! Do I just plug it into the same home network as my original station? Does it need to be programmed so the two base stations work together with the six cameras? And which base station should I buy? I have only Arlo Pro two cameras and do not need a siren.
I think this is a dupe post - I answered in the other.
thanks!!
