Removing Arlo Pro 3 screw in mount from camera
I used the screw in mount and would now like to try the magnetic mount. How to i remove the screw in mount trom camera?
The screw is connected to the mount so try unscrewing the cam from the mount unless I misunderstood and the screw broke.
Just unscrew from back of camera. Reverse the step you took to attach it.
I prefer the screw mount to the magnetic BTW.
