  • 6 Replies
  • 3620 Views
CelP
My cameras were working for the last 2-3 months.  My cloud service expired.  The recordings are not showing up in the library.  Do I need to put a USB drive in the base for the recordings to show up in the library on my phone?
Please help.  Thank you.
Without a subscription your only choice is to record locally so, yes, you need to install a USB drive (a thumb drive is recommended for space needed and ease of removal).
6 REPLIES 6
CelP
Thank you.
CDPerron
I have the 4500 base station with a usb drive for storage. I can’t get my pro 3 camera to record. It also doesn’t seem that the activity zones are accurate for motion sensing. Is there something specific I need to do to get this working properly.
CDPerron,
What mode are you using? Are the rules set up correctly for the Pro 3 camera?
CDPerron
Yes. All of the rules are set up correctly as they are with my arlo 2’s to record. I’m using the “armed” mode through my base station which has a usb drive inserted l. Camera is plugged into power, camera set to record video when motion is detected. Push notifications also turned on.
Is there any way I can get on the phone with you? It appears that this is an extremely common issue.
CDPerron,
If you would like to contact support and speak with someone about this issue, take a look at the options found here: Arlo Support Center
  • 6 Replies
  • 3621 Views
