Range reduction in the past 10 Days?
Has anybody had their range drop off in the last week or so? Base station Firmware 1.16.5.0_848_89fcc16. I have three Pro3 cameras. The farthest ones usually have 1-2 bars of signal. Now they just cut out half way walking out to their mounts. Full batteries etc. This just started happening after working fine for months. Granted it could be some new interference in the neighborhood but range has been cut in half essentially. Anybody else have this issue?
Mine are still working fine with no reduction in distance. Reboot your base to see if that helps.
Thanks, I had tried that. I work in IT so I'm used to troubleshooting these things. It was driving me crazy. The only thing that worked was resetting the base station and re-adding/resyncing the base station and cameras. Basically start from scratch with a system that was fine for months. Now it works fine. Nothing had changed before that. Very odd. Hope that helps somebody else.
