Pro 3 second charger and cord - unavailable
I have the Pro 3 2 camera pack. It came with only 1 charger and cord. Since I have power available at both camera locations I want to plug the 2nd camera in 24/7, the same as the other camera. I am unable to find a second charger and cable. The only thing available, anywhere I can find is at least 20'. I only need the ~3' cable. Arlo does not supply the cable that came in the box.
Any suggestions? Also, what if that charging cable is lost or damaged? I can not believe a replacement is not available.
Thanks,
SD
For use with Ultra, Pro 3, and Pro 3 Floodlight Cameras.... you may have to look as out of stock but any one that works on Ultra works on P3 search for VMA5000C
looks good here
https://www.homedepot.com/p/ARLO-Indoor-Magnetic-Charging-Cable-White-VMA5000C-100NAS/312830100
Thank you for that. 8' is at least somewhat reasonable when compared to 20' or more.
SD
