Pro 3 cam no live feed AGAIN
2.5 yr old pro 3 cam not working on live feed last few weeks again. I will record and The other 3 cams work just fine. Im guessing they sent another bad update?
Working fine here. Not likely an update issue since it seems to be a local issue. Have you rebooted your hub and maybe reinserted the camera battery to get to a known config? Worst case, removinng the camera from your account and reinstalling should fix any weirdness.
I rebooted the Hub as well as removed device in question and tried to reinstall it. However, it doesn't come online. It's fully charged and the solar panel works because I tested it with my other camera. What shall I do now? Purchase a replacement camera?
Certainly a possibly faulty camera. If you have a subscription use Settings, Support (Center) to choose your camera model and start talking to official support for a possible RMA.
