One of my 3 cameras worked fine for a couple of months. Then, its battery starting going to near zero in a few days. I changed the battery and the samething occured. I am get only a few pushes a day so I am reasonably sure it is a camera issue. The camera is about 9 months old.
Swap cameras around to see if it's the camera or location.
Thanks. I made the swap and the problem moved with the camera. The camera is less than a year old. I have seen some similar complaints on line. Does Arlo back the product when it has this problem?
You do realize the camera/system has a 1 year warranty, right? Use it by clicking on the Contact Support link at the bottom here.
I have contacted Arlo support and have not received a response.
STay on them. Respond on your own.
Thanks.
Well, it has been a week since I contacted Customer Support. They assigned me a case number and I have heard nothing since. This lack of service seems to match comments I have read from other customers. Not good.
