Pink and red picture
  • 2 Replies
  • 788 Views
Jinesh28
Hello team
I’m having an issue with my camera quality. I am seeing a red and pink picture. Only one camera other two camera is working perfectly fine.
This suggests a stuck Nightvision (IR) filter.
Is the camera still under warranty?
You can try removing the battery for about 10 seconds, and reinserting it. Shaking or tapping the camera against a table might also release it. Some have found that sliding a strong magnet under the camera also does the trick.
royemello
remove battery's = flip upside dwn  - tap camera on hard surface. install battery's - your hear it click. if do it again till it does. inferred relay sticking
 works for me - done it many times
 bad relay in camera -
 if battery's become low - it can cause it on a restart IE pwr goes out etc.
  • 2 Replies
  • 789 Views
