Order replacement wall mount for arlo 3
Is it possible to order a replacement wall mount that comes with the arlo 3?
Or is there a recommended option other than the stock mount?
Magnetic mounts are available
- https://www.arlo.com/en-us/accessories/VMA5001-10000S.html
- https://www.arlo.com/en-us/accessories/VMA5000-10000S.html
So are several other Arlo screw mounts. The thread is standard, so a wide variety of third-party mounts will also work.
