vfe,
Do you have an active Arlo Smart subscription for your Arlo Pro 3 camera? Arlo Pro 3 requires a subscription to an Arlo Smart plan to save recordings to the library. For more information on subscription plans, take a look here: What are the available Arlo subscription plans and how much cloud recording is available?
vfe,
I guess I was not aware that I would not be able to even have the 7 days like my other Arlo cameras with the pro 3. I wish that had been more clear. I guess I will have to buy a subscription or get a different model.
@vfe You can use local storage with USB. With it limitations though for me the subscription is worth it to view on cloud and smart notification but that up to you.
https://kb.arlo.com/1146850/How-do-I-view-videos-saved-on-a-local-storage-USB-device
