Not really sure of the model numbers. They are 2 years old and 4 yr
  • 1 Reply
  • 363 Views
RudyO
Outside Arlo Cameras how do you set the camera time?
They are exactly 6 hours behind the right time.
Thx
Do you use a base/smarthub?
Do you see "Library" in your app interface?  Or do you see "Feed" and "Dashboard" instead?
It'd be helpful to know them.
If the cameras come out of the housing, then take one out and remove the battery.  There is label inside.  If the cameras are fully sealed, then look for a camera model on the shell - usually it is near (or on) the rubber gasket that protects the charging port.  It is small print, and low-contrast, so easy to miss.
If you also have a base/smarthub, then look on the base for a VMBxxxx label.
Alternatively, go into the support center in the app, and select the camera.  Scroll down to the Product field, and you will see the camera model.  If you see Hxx, then you are looking in the wrong place.
  • 1 Reply
  • 364 Views
