Looks like there is a bug in the system I'm unable to set up a schedule from 8 pm to 7 am.
It's a long standing limitation.
You need to create two entries - one from 8 pm to 11:59, the other from midnight to 7 am. You will get continuous coverage (the first entry ends at the end of the last second of the interval, the second entry begins at the beginning of the first second in the interval).
Thank you StephenB, that for sure should work!!
