Use the app and check Settings, Support. As a new install, you should have access to a phone number as well as chat. You may need to go through the chatbot to the end and say the problem hasn't been resolved.
I'd try a different battery in the camera as well as a different camera so you can mix and match batteries and cameras to determine what the problem is.
And I can try your suggestion, but the larger question about what to do about this w Arlo?
You'd need to swap the whole package at the store for fastest resolution.
