My router only has one eithernet connection. How do I connect base station
Received cameras. My router only has one eithernet connection. How do I connect base station
@Valvan wrote:
Received cameras. My router only has one ethernet connection. How do I connect base station
If you are already using that ethernet port for another device, then you'll either need a new router with more ports, or you'll need to purchase a gigabit ethernet switch. 5 port switches are inexpensive.
