Motion detected but will not record
  • 1 Reply
  • 505 Views
smorganhoffman
I have 3 arlo cameras that are not working. They detect motion but do not record. I checked the rules and after detecting motion the next step is suppose to record but mine says to do nothing. I tried clicking on recordbut nothing is happening. I also tried taking the battery out nothing happened. Do i need to buy a subscription inorder for it to record. Or should it record without a subscription
@smorganhoffman wrote:
 Do i need to buy a subscription in order for it to record. Or should it record without a subscription
That depends on what camera you have (and whether or not you use a base station)  What cameras do you have?  If you have a base/smarthub, then what model is that?
Note that if you just purchased, you should have been automatically opted into a 3-month free trial subscription.
  • 1 Reply
  • 506 Views
