I am considering purchasing the Arlo Pro 3 camera system. I currently have the Arlo Pro and did not use a mount for the cameras - just attached the camera with the magnetic back to a metal door frame and outdoor light fixture because the stucco on the house is too difficult to screw a mount into. My question is will this be possible to do with the Arlo Pro 3 or do you have to attach the magnetic mount?
Pro 3 magnetic mounts have to be screwed to a surface.
The mount is the magnetic bit, not the camera.
Just another user
Just another user
PS
The older cameras had the magnets in the camera, Arlo,Pro,Pro2
so it was possible but not with newer cams
Thanks!
