Local USB Storage for Arlo Pro 3
- I bough this model because of the Local USB Storage features.
So far nothing work, I bough :
1- Seagate 8 TB USB 3.0 / 2.0 Model STEL800400`
2-Toshiba 2TB USB 3.0 / 2.0 Model V 73600
3- Seagate 2 TB USB 3.0 / 2.0 Model SRD00F1
all FAT 32
Needed Helps Please
While it could be some sort of incompatibility, it could also be a current supply issue if these drives draw current from the USB port and don't have an external power supply. A cheaper and easier to use solution is to just use a thumb drive of 32-64GB capacity. That size will hold a lot of videos - usually no need for massive drives.
I am using an old Seagate 500 GB full size external hard drive with plug in power supply. No problems at all with that type of drive.
