  • 1345 Views
jgroves
I have Arlo Pro 2 & Arlo Pro 3 (two locations) - 5 cameras on each base station.  I keep getting a warning to create activity zone on two cameras (both are pro 2) even though I have zones setup.  I have tried removing and re-adding the zone over and over.
jgroves,
Are you able to dismiss the message? Does it return if you log out and back in. Which app are you using (iOS, Android) and does this also occur when using the web client?
jgroves
It is only happening on the web client (which I use a good bit).  If I dismiss it, the message comes back or I have the little warning icon in the lower right.
MJanis
I have the Ultra cameras and Smart Hub.  I have been getting the same message when I log into Arlo thru my computer.  I have also tried creating new zones or updating the created zones but still get the same message on all the cameras.
A solution would be much appreciated.
Thanks,
  • 1346 Views
