Hi,
I have tried reading all topics regarding limitations on cameras live streaming.
I have a store where I need 12 cameras to cover the area. As I read it a base can handle up to 15 cameras, you just have to upgrade your plan. But we need to be able see all active (with motion detected) cameras on a widescreen to monitor the area. Is this still limited to max of 5? I guess we can easily have 8 - 10 cameras with motion detected at the same time.
Best regards from Denmark and I look forward hearing from you.
TBMK, this has not changed... the max streaming at the same time is 5.
* ( also be careful of data thru-put as your upstream would need to be robust )
But there are ways around this. Arlo does have a commercial service plan ( unknown info here, see below ) and/or it can be done with multi bases.
3 base units on an account would prob allow what you need and all would show on same screen,
https://kb.arlo.com/1226981/How-can-I-use-Arlo-to-monitor-my-organization-or-business
https://kb.arlo.com/1202808/What-Arlo-business-subscription-plans-are-available
Many thanks.
I will look into the commercial plans
