Is a central or control station needed?
  • 1 Reply
  • 1594 Views
ernesetoariel
Does the VMC4040P or the Ultra require a base station or control station of some sort?
As I review the cameras I can't find any information on the requirement to use a central station.
I plan to use all wifi/wireless cameras (only 3-4 in total, including the doorbell). Any documentation on the actual system design/architecture/configuration/manual would be appreciated. Thanks.
Both the Pro 3 and the Ultra/Ultra2 require a base station.  The base station is connected to your local network via ethernet, and it creates a closed wifi network for the cameras to use.
You can add local storage to the base station, which can act as a either a backup or a a substitute for the cloud storage.
With these particular cameras, I'd recommend getting a smarthub (VMB4540 or VMB5000)
The Pro 4 cameras can connect either directly to your home wifi network, or to a base station.
The essential cameras (which are 1080) can also connect to either your home wifi or to a base.
  • 1 Reply
  • 1595 Views
