Introducing Arlo Pro 3 - FAQ & Resources
- 2
Shine Like a Pro.
Keep an eye on your home or business day and night with Arlo Pro 3. Easily install in minutes, and view video directly from your phone.
For more information about your Arlo Pro 3 System, and some other helpful resources, check out the links below:
Arlo Knowledge Base
- Arlo Pro 3 FAQ
What are the features and specifications of the Arlo Pro 3 camera?
- What kind of features do I get with the Arlo Pro 3 camera?
- How is Arlo Pro 3 different from Arlo Pro 2?
- Is Arlo Pro 3 backwards compatible with my existing Arlo system?
- How does my Arlo Pro 3 camera use 2K?
YouTube
- Unboxing the Arlo Pro 3 Wire-Free Security Camera
- How-to Set Up Arlo Pro 3 Wire-Free Security Cameras
If you have any questions about the Arlo Pro 3 system, post down below and we'll get to each one as soon as we can. If you need additional help, visit Arlo Support for more articles and resources.
Buy your Arlo Pro 3 System now at Best Buy!
Thank you for being part of the Arlo family!
I purchased 10 days ago.
I have lost connectivity to smart hub every day. All 3 cameras are within 100 feet of base. 2 have zero walls blocking it. All 3 stop connecting at same time.
My smart hub is connected straight to my main supply router. I have great internet speed. Up and down .
I have changed cables. I have reset system completely .
What else can I try?
Also, all batteries are needing to be charged every 2.5 days.
Bskit88,
Battery drain is often a result of lost connectivity when experiencing symptoms like you describe. What does the signal strength icon show when the cameras are online?
You might try moving your SmartHub away from your router, if it's close, the router could be interfering with connectivity between the SmartHub and cameras.
Regardless of the marketing hype, 100 feet (30 metres) may be pushing limits.
Can you experiment with shorter distances?
Just another user
Thank you James for the response.
My signal strength icon is full on all 3 cameras when working.
My smart hub was about 3 feet from router. Now, I have stretched cable to the limit and it is about 10 feet from router.
Do you think 10 feet is sufficient or get a longer rj-45 cable?
I will try it like that and let you know.
Thank you for the reply.
2 cameras are at 16 feet now and farthest is at 35 feet.
And my base is 10 feet away from router. Will give that a try.
Thank you
Thanks!
@Shaun1234 wrote:
I'm in the UK, every shop has to give a 1 year warranty
Until we finally leave the EU, it is more like two years minimum, sometimes six. It depends on what you bought.
One year is what the manufacturers try to get away with. They are wrong.
Just another user
Not sure if this is relevant to but up until September I was getting all recordings no matter if on or off in smart to cloud but no notifications for those off. Now I just get the recordings for those selected on cloud but the others are on the Hub. I have seen conflicting post on which way it is suppose to work for cloud but that's how it works for me now.
How do you setup if you don't have a router to plug into? I only have wireless.
Sorry you need a router as the hub isnt wireless
I have a hotspot. I live in a rural area and internet access is limited to a few options.
Also the Pro 4 cam connects to wifi without a Hub and is like the Pro3 that needs the Hub. Make sure you have enough upload speed using a Hot Spot.
- 2
