Indoor camera only on 0600-2300
I want my indoor camera only to be schedule to arm at 2300 and to disarm at 0600 the following morning.
Have you read the FAQs here on modes, rules and scheduling, as well as a whole host of other topics?
Mode tab, click on your base/hub and edit the Armed mode (or create your own custom mode). Make sure the settings are as you need. If more modes are needed, create them now. The edit the schedule to add your mode(s) in the apppropriate days and time periods. You can't cross past midnight so the time should be set from 11:00PM to 11:59PM (set the end time first to avoid error messages) and then set a new time period for the same mode from 12:00AM to 6:00AM.
Cjctblaze,
You will need to set up a custom mode and include rules only for the desired camera and then slot that custom mode into your schedule during the desired time frames.
For more information on custom modes, take a look here: How do I create a mode with different rules for each Arlo Wire-Free or Arlo Pro Wire-Free camera?
