No...
The cameras trigger on motion and record for a set of time ( depnds on yr settings; "till motion stops" or "fixed" ).
If you have the CVR option they record 24/7 which may help.
I usu use a Fixed time and may be your sense level needs to be turned up to capture sooner... remember that max distance is 25ft +/- for detection
Thank you for your reply. So far I’m not too impressed with these cameras.
I guess I’ll look up how to change it to a fixed time.
Read the FAQs here in the support section as to how to change recording time and motion sensitivity as well as best camera positioning (along with a whole slew of other topics). Recording starting when the subject is departing isn't a recording duration issue, it's a positioning one.
PIR detectors work best when motion is across the FOV, not at the camera. Increasing sensitivity can also be useful. Post a screenshot of the camera view for suggestions.
love it thank for the valuable information…
