How to get my camera participating
  • 1 Reply
  • 919 Views
amyhorrocks
I don't know how to find which camera I'm using. UGH
Beyond that, my free subscription just ran out and I paid with my cc for a monthly EXCEPT I don't know how to link my camera with my plan to activate the library again.
Are there any humans that work for Arlo that we can contact for support?
Not sure what you mean.
If you want to identify the camera model - do you have a camera with a removable battery?  Or is the case completely sealed?
If the battery can be removed, then you open the shell and remove the battery.  Then look for a label that starts with VMC.
Go into the subscription area of the app, and then select "manage cameras".  Cameras in the "no plan" list can be  dragged into the subscription.
If you use the support area in the app, then you should find a phone option (since you have a subscription).
  • 1 Reply
  • 920 Views
