  • 1 Reply
  • 576 Views
joemcarlin
I have a new system that I am installing in a second home. How best to setup so that both systems can be monitored independently?
joemcarlin,
You could create a new account if you want the system to be entirely separate, otherwise, you can add the second system to your existing account and re-name the SmartHub and cameras so that they indicate the second residence. The cameras will behave according to the modes/rules for the SmartHub to which they are synced, this allows the operation at each location to be independent even if they are on the same account.
  • 1 Reply
  • 577 Views
