Help reaching support
  • 1 Reply
  • 888 Views
KELLYGIURBINO
I have the Arlo Pro 3 cameras and the Arlo box/modem/whatever is red light dead. IS IT THE PRO3 or ?????
Best answers
  • jguerdat
    What have you tried and what do you see? All details are needed. It sounds like you're referring to the hub's LED being stuck on amber (red). Is that correct? Does your router's settings show that the hub has been assigned an IP address?  Have you rebooted the router and hub, in that order? Is this a new install, a reinstall, or troubleshooting something like offline?
  • 1 Reply
  • 889 Views
