Help finding an adapter
Bonjour
impossible de trouver un adaptateur de smart Hub
le mien ne fonctionne plus
@Arlo20232023 wrote:
Bonjour
There are several third-party adapters that say they are compatible. Try including both the smarthub model and the part number on the adapter in your search.
