Find out my model number of my camera
I would like to purchase a solar charger for my wireless camera. How do I know what type of camera I have?
You usually find a label inside the battery compartment of the camera. Should start with VMCxxxx. If you have multiple batteries then it would be the earlier netgear camera.
https://www.arlo.com/en_dk/support/faq/290/What-kind-of-batteries-does-my-Arlo-camera-use
Even more quickly, check the usual charging connection. If it's magnetic, be sure to get the panel that uses that connection. The others use a microUSB port.
