Fiber optic 5ghz only
  • 2 Antworten
  • 2113 Aufrufe
  • 2 in Unterhaltung
custom-tiles
Just dropped Comcast for fiber optic line. Router only offers 5ghz, can't seem to set my camera to 5ghz. What's my solution to connect my camera?
2 ANTWORTEN 2
BrookeN
You can get a base station or smart hub or or get a router with 2.4ghz SSID. The only camera that works with 5ghz is the pro 5.
custom-tiles
"The only camera that works with 5ghz is the pro 5" - a brief look at the online setup instructions appears to say it must be setup in 2.4 and then can be switched to 5.0  ----  is this true or can the pro 5 be set up and continue to work in 5.0?
  • 2 Antworten
  • 2114 Aufrufe
  • 2 in Unterhaltung
