Door Camera work with Pro 3 Base station
I have the Pro 3 4cameras
and wanting to add a door camera that work with the base station to record the video to the base station
So I need a part number of the door camera?
The compatibility list is here:
If you mean a video doorbell, your two options are the AVD1001 and AVD2001.
If you mean a camera, then your options are Pro 4, Pro 5s, Ultra, and Essential Gen 1.
Be careful to avoid the Essential Gen 2 models, as they cannot be paired with a base yet. Arlo says they will add that capability, but they haven't said when.
The Pro and Ultra models use the same batteries and chargers as your Pro 3 cameras. The Essentials are all sealed (the battery is not user-replacable), and they charge with a microUSB cable. (Gen 2 charges with USB-C).
