Cover for outdoor camera
For the best coverage of my backyard I need to mount the camera to a location that is in direct sunlight.
Can anyone recommend a cover that fits the camera and shields it from the sun?
You'd have to find a place that's shielded or maybe build your own shield or box to help. Of course the extreme wide angle of the lens still means the camera would have to sit at the front edge to avoid having any shield be in view. Rotating the camera down as much as possible may be the best solution.
