Connecting VMB4540 to Homekit
  • 17 Replies
  • 5469 Views
  • 2 Likes
  • 9 In Conversation
kirktrue
Hi Arlo folks!
I recently changed my home Wifi and I'm unable to connect my Arlo base station (VMB4540) to HomeKit. I am using the app, select the base station, and click "HomeKit" but it just stays stuck on the "Discovering your device. Please wait." screen forever.
I've gone through https://kb.arlo.com/000062688/How-to-troubleshoot-Apple-HomeKit-issues-for-Arlo-devices but it has not fixed anything 😞
I read about some token reset process on various forums, but I'm not sure if that's what's needed, and if so, how to start the process.
Thanks!
BrookeN
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions
:How do I connect my Arlo device to Apple HomeKit?
https://kb.arlo.com/000063184
17 REPLIES 17
BrookeN
kirktrue
Thank you! That worked perfectly!
kitora
Can you provide the same for me? Just bought a 4540 and I have the same issue.
BrookeN
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:
kitora
That worked. Thanks!
Jmorreale22
Could you do the same for me please?
reckless-ranch
I need a token reset as well, please.
BrookeN
reckless-ranch
That fixed it.  Thank you very much!
casadurso
I seem to be in the same situation with the “Discovering your device. Please wait” with the spinning Devices found icon. Can you send a token?
BrookeN
Defaultuser
Hi can I please get a token reset sent as well?
BrookeN
I sure can. I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:
Jascyl
I have the same problem after changing to another broadband company with a new router.  Could you send me a rest token so that I could try to connect my VMB4540 to homekit.
BrookeN
Chia305
Hello can I request a token reset please. Thank you
BrookeN
  • 17 Replies
  • 5470 Views
  • 2 Likes
  • 9 In Conversation
