Connect Arlo to Synology DS220j file server using a USB cable
Trying to connect my arlo 3 pro using the VMB4540 hub and USB cable. I have the cable in place however I cannot activate the Record Locally button. As if it does not recognize the port. Any suggestion is appreciated.
Any NAS I know of uses its USB port only for import from an existing drive. Thus, this connection won't work. All you can do is to record to a thumb drive and then transfer manually to your NAS.
