Can't access local storage any more
I have an android, my wife has Apple
It has been about 1 week since we.lost capability to access local storage for our Pro 3 cameras. I was viewing them about a week ago, now there is nothing. I recall their being a drop down to select the cloud or storage device... that doesn't exist any more. I've restarted the base station, checked wifi settings, pulled the USB and reinstalled, toggled the settings, and verified all settings are set. The Pro 2 cameras work fine, along with the Arlo Baby. The Pro 3 cameras can be viewed love and also receive the proper notifications for audio and motion... just can't access the local storage device to see what was recorded
Have you rebooted the phones and reinstalled the app?
Try rebooting the router and hub, in that order. Have you tried a different drive which was formatted in the hub? After you safely eject the drive, do local recordings show when viewed on a computer?
The drop down to choose base station or cloud storage has disappeared. The cameras still record and notify correctly. If I pull the storage and put in a computer, I can see the recordings.
Everything points to being an app version issue since updating past 3.6.4
@Wolfy13 wrote:
My iPad has version 3.6.4, and it has access to the storage. My phones are updated to 3.6.5 and they do not have access... obviously pointing to an app/update problem
I'm thinking it's more complicated than that.
I have 3.6.5. My iPad and iPhone both can access local recordings on one of my VMB5000 bases, but not the other one. Recordings are still being made, and both are set up to use direct access to local storage.
This is not a new issue for me, 3.6.4 behaved the same way.
@Wolfy13 wrote:
Weird...
I agree.
Does this issue still occur with app v3.6.6 for iOS & 3.6.6/3.6.8 for Android?
The 3.6.8 update for Android is in a phased release, so you may not have the update in the Google play store just yet.
Yes it still happens on 3.6.6 on Android.. Arlo web devs, are the worst I have ever seen. This works perfectly with my Arlo Pro 2 base/cameras. I'm going to package up the Arlo 3 pro system and sell the whole thing.
Have you rebooted the hub as well as checked the setting for local storage in the hub's settings? If you remove the drive safely and view on a computer, are there appropriate videos? Have you rebooted the phone and reinstalled the app?
@Jayfkuul
Are you still experiencing this issue?
The local storage isnt viewable in my Android, my wife's iPhone or from an android tablet.
@Jayfkuul
Were you able to provide these details to the L3 team?
It looks like Jeff from the Support team has reached out regarding this issue.
This run around trying to say otherwise, is a complete Netgear turn off.
