Camera the picture shows pink
I have a pro 3 camera that the picture shows pink. What could cause this and how to correct
Sounds like the IR filter used for night vision is stuck. You can try reinserting the battery to clear it but you may also need to reasonably thump the camera to see if you can unstick it. If nothing works, use the app to go to Settings, Support and choose your camera. Scroll down to Contacts to see what official support may offer.
