Camera constantly recording
Why is my camera nearly constantly recording images? I lowered the movement sensitivity down to 30 percent though I am experiencing the same issues.
Did you lower the sensitivity in the test, or did you edit the rule in the modes you have configured? It needs to be done in the mode/rules.
Also make sure audio detection is turned off.
